Volume value mapping problem
  • Volume value mapping problem
    I have a problem when i adjust the volume from the regular remote control. If the new volume has a value with decimal .5 (-59.5db), the volume slider goes to max.
    This is info for -59,5dB:
    Status 205 = Unknown
    Value 205
    String -59,5dB
    This is info for -60,0dB:
    Status 20 = Dim
    Value 20 = "20"
    String -60,0dB
    When volume is set a value without decimals, then slider is correct again. It's a Denon 4310 receiver. I tried to switch to 0-100 mode for volume in the receiver, but it doesn't make any differences since receiver still use 0.5 steps.
    FYI.
    Solved in 2.0.27 (in the HS3 updater)
    Thanks.
