I have tried to use this plugin but it has been very intermittent. I reinstalled HS recently and I decided to try the plugin and it actually worked for a while. Here is what I see in the HS log:
The Onkyo controller app works just fine.
May-14 2:43:33 PM | drhsIpPlugIn | Starting Tcp client for Onkyo at address 192.168.1.7:60128 |
May-14 2:43:33 PM | drhsIpPlugIn | Watchdog restarting stalled connection for Onkyo |
May-14 2:43:25 PM | Plug-In | Finished initializing plug-in BLOnkyo |
May-14 2:43:25 PM | Starting Plug-In | BLOnkyo loaded in 399 milliseconds |
May-14 2:43:25 PM | Starting Plug-In | Plugin BLOnkyo started successfully in 61 milliseconds |
May-14 2:43:25 PM | BLOnkyo start | BLOnkyo plugin has been initialized |
May-14 2:43:25 PM | BLOnkyo start | Receivers have been loaded. |
May-14 2:43:25 PM | BLOnkyo warning | BLOnkyo Debug Logging is Enabled! |
May-14 2:43:25 PM | BLOnkyo start | Loaded configuration successfully |
May-14 2:43:25 PM | BLOnkyo start | BLOnkyo version is: 2.0.66.0 |
May-14 2:43:25 PM | BLOnkyo start | Initializing BLOnkyo... |
May-14 2:43:25 PM | Starting Plug-In | Initializing plugin BLOnkyo ... |
May-14 2:43:25 PM | Info | Plugin BLOnkyo has connected. IP:127.0.0.1:62268 |
May-14 2:42:48 PM | Plug-In | Shutting down Plug-In: BLOnkyo |
