Humm. It 'suddenly' started to work.
Blade, thanks, the detailed log does help.
NicolaiL it might indeed be my HS2 system locking it.
Only one can be connected, as I read.
Let's see if it keeps working. I hope if I can narrow it down later.
Greetings!
Frank
No Log No action.
There are no errors in the log.
It looks like it connected to your receiver just fine.
Did you try adding any Denon commands and trying them and see if they work.
It does not look like you did anything but start HS3 and shut it down.
found the log
NicolaiL: yes both are in there.
Blade, Attached the log. not sure what to read in it. Hope you can give me a clue.
FrankAttached FilesLast edited by fvr; February 5, 2014, 05:41 AM.
Originally posted by fvr View PostBob,
I've installed the BLOnkyo plugin, everything looks okay, but the receiver does not respond.
I've tried. Detailed loggin, but I only see:
Feb-03 7:58:24 AM Event Event Trigger "Audio Stereo Uit" Feb-03 7:58:24 AM Event Event Audio Stereo Uit triggered by the event page 'Run' button.
Any tips on troubleshooting this ?
Thanks !
Frank.
If you turn on debug logging it creates a BLOnkyo-Detailed.log file in your HS root
Capture the issue and post the log
No Log No action.
Bob,
Thanks !
Frank.
