where do i start help appreciated
    Hi Guys,
    Is there any help file with this plugin, Just starting to look at HS3 which seem daunting to say the lease,
    In HS2 I was using an Onkyo plugin that created a device, but this one seem to do a different way, but I am not sure how
    Any help would be greatly appreciated
    well I finally managed to sort it,
      I must have missed this post.
      Glad you got it going. I plan to add to this plugin. Just need to carve out some time.
      I wrote this one on Christmas day
      Cheers,
      Bob
        S.Morris I'm using this plug-in too so if you have specific questions let me know and I might be able to help.
        Nicolai L
          Hi Guys,
          Thanks for the replies, Just for your info I am using an (UK) Onkyo TX-NR1009
          In HS2 I am using an Onkyo plugin that allows me to use a slider button in HSTouch to adjust the volume up and down, is that going to doable with this plugin, and I am assuming that most the command are in the Onkyo .XLS that explains how the codes are built up which I have attached incase any of you find it useful.
          Must admit it been along time since i set thing up in HS2 and it seem like I will have to do some studying to get back up to speed and now I would like to try HS3 so any help you guys can give me would be greatly appreciated.
          Update*****
          Hi Blade, I see you do a volume plugin, would that help with my sliding volume, as per question above or is there a simpler solution
            Originally posted by S.Morris View Post
            Hi Guys,
            Update*****
            I think I use the same HS2 plug-in as you
            I have already raised an enhancement request for Blade for the slider device (plus a few other things I think would be helpful, check his site).
            For the time being I'm limiting myself to Vol Up/Down commands an simple buttons in HST.
            I'm pretty sure some clever scripting could be use with HST to to give you a slider, but I haven't the time to write this so I'm keeping my fingers crossed for Blade to do enhancement sometime in the future.
            Nicolai L
