where do i start help appreciated
  • NicolaiL
    Originally posted by S.Morris View Post
    Hi Guys,
    Thanks for the replies, Just for your info I am using an (UK) Onkyo TX-NR1009
    In HS2 I am using an Onkyo plugin that allows me to use a slider button in HSTouch to adjust the volume up and down, is that going to doable with this plugin, and I am assuming that most the command are in the Onkyo .XLS that explains how the codes are built up which I have attached incase any of you find it useful.
    Must admit it been along time since i set thing up in HS2 and it seem like I will have to do some studying to get back up to speed and now I would like to try HS3 so any help you guys can give me would be greatly appreciated.
    Update*****
    Hi Blade, I see you do a volume plugin, would that help with my sliding volume, as per question above or is there a simpler solution
    I think I use the same HS2 plug-in as you
    I have already raised an enhancement request for Blade for the slider device (plus a few other things I think would be helpful, check his site).
    For the time being I'm limiting myself to Vol Up/Down commands an simple buttons in HST.
    I'm pretty sure some clever scripting could be use with HST to to give you a slider, but I haven't the time to write this so I'm keeping my fingers crossed for Blade to do enhancement sometime in the future.
  • S.Morris
    Hi Guys,
    Update*****
  • NicolaiL
    S.Morris I'm using this plug-in too so if you have specific questions let me know and I might be able to help.
  • Blade
    I must have missed this post.
    Glad you got it going. I plan to add to this plugin. Just need to carve out some time.
    I wrote this one on Christmas day
  • S.Morris
    well I finally managed to sort it,
  • S.Morris
    started a topic where do i start help appreciated
    Hi Guys,
    Is there any help file with this plugin, Just starting to look at HS3 which seem daunting to say the lease,
    In HS2 I was using an Onkyo plugin that created a device, but this one seem to do a different way, but I am not sure how
    Any help would be greatly appreciated
