New Update
  • New Update
    Hi Blade what was in the new update 2.0.4.0 any goodies
    right plugin this time
    The latest BLOnkyo has devices in it.
    I think you will like it. It is much more complete now
    Cheers,
    Bob
      Will it auto update the devices etc, At the moment only seeing 4 devices and thing don't look any different, sorry,
      Are the changes in the commands section
      appreciate your work
        What version are you running right now?
        Cheers,
        Bob
          Hi Blade
          Running the new one that was in the updater think its 2.0.4.0, updated last night, reset the plugin and just rebooted HS3
            would the receiver need to be on
              Hi Blade,
              How does the connect work, at the moment when power is applied to the amp it take around 45 seconds to establish a connection, would the connect improve on that ?
                As long as the receiver is plugged in it should connect to it.
                2.0.4 is the latest
                I would do the following to get fresh devices created
                1. Disable BLOnkyo
                2. Go to the device management page and delete all devices owned by BLOnkyo
                3. Re-enable BLOnkyo
                It should create the devices when it starts.
                You will need to edit each receiver you have set up in the plugin and check the zones you want to use for the receiver.
                Let me know
                Cheers,
                Bob
                  will this upset any event that are set to this amp or just the events using the devices that are created at present
                    Just the events using any of the current devices for BLOnkyo
                    Cheers,
                    Bob
                      thanks
                        2.0.4 is the latest
                        1. Disable BLOnkyo
                        Let me know
                        Hi blade,
                        Did as you suggested but still only seeing the same 4 devices no new one
                          Did you enable the other zones when editing the receiver in the plugin?
                          Cheers,
                          Bob
                            No, don't really use the other zones, I have just tried uninstalling then reinstalling the plugin but everything seem the same.
                              Show me a screenshot of what devices you are seeing?
                              You will only get one for power, volume, mute and input I think
                              Cheers,
                              Bob
