If this is your first visit, be sure to check out the FAQ. You must register before you can post. Your first post will be checked for appropriate content
(SPAM) - please allow a bit of time for that. After that, you'll be able to post at will!
Will it auto update the devices etc, At the moment only seeing 4 devices and thing don't look any different, sorry,
Are the changes in the commands section
How does the connect work, at the moment when power is applied to the amp it take around 45 seconds to establish a connection, would the connect improve on that ?
As long as the receiver is plugged in it should connect to it.
2.0.4 is the latest
I would do the following to get fresh devices created
1. Disable BLOnkyo
2. Go to the device management page and delete all devices owned by BLOnkyo
3. Re-enable BLOnkyo
It should create the devices when it starts.
You will need to edit each receiver you have set up in the plugin and check the zones you want to use for the receiver.
2.0.4 is the latest
1. Disable BLOnkyo
Let me know
Hi blade,
Did as you suggested but still only seeing the same 4 devices no new one
