Reciever Vanishes after Reboot
  • Reciever Vanishes after Reboot
    For some reason my reciever vanishes from the list when I reboot my HS3 server.
    The devices remain and then I just add the reciever again and it all works again.. BUT of course I am rebooting twice a day to deal with the other HS3 issues.
    Any thoughts, I really enjoy this plugin.
    I bet you it has to do with the saveINISetting issue in HS3
    What version of HS3 are you running?
    Cheers,
    Bob
      I am cutting myself with the Beta at the moment .125
      HS3 Pro Edition 3.0.0.125 (Windows)
        I see the issues now in the boards
        yikes, that is a major issue, I hope they get it fixed shortly.
          Yes that is likely the issue
          Can you paste in your hspi_BLOnkyo.ini file
          Surround it with the code tags, like this:
          Here is the INI contents
          Cheers,
          Bob
            here is the INI file
            [Settings]
            supportForumUrl=http://forums.homeseer.com/forumdisplay.php?f=1178
            debugLevel=true
            receiverPollingSeconds=5
            helpFolder=/BLHelp/
            [Receiver Commands]
            command_PWR00=PWR00|Power Standby
            command_PWR01=PWR01|Power On
            command_AMT00=AMT00|Mute Off
            command_AMT01=AMT01|Mute On
            command_SPA00=SPA00|Speaker A Off
            command_SPA01=SPA01|Speaker A On
            command_SPB00=SPB00|Speaker B Off
            command_SPB01=SPB01|Speaker B On
            command_MVLUP=MVLUP|Master Volume Up
            command_MVLDOWN=MVLDOWN|Master Volume Down
            command_NPR28=NPR28|Internet Radio 28
            [Receiver=1]
            number=1
              Yep that is the issue. See the [Receiver=1] section is pretty much blank
              Shutdown HS3 and delete the following lines from the hspi_BLOnkyo.ini file:
              [Receiver=1]
              number=1
              Then restart HS3 and add your receiver back.
              After you add the receiver, add a 2nd receiver and just make it up. Once the 2nd one is added, go back and edit the 2nd made up receiver and delete it in the plugin
              Then try a restart and see if the first receiver stays.
              BTW... the issue is supposed to fixed in HS3 3.0.0.130. I really hope they release it soon because this issue has the ability to cause all sorts of issues for people
              Cheers,
              Bob
                Yep that worked!
                Thanks for the help, that tricked it into only deleting most of #2.
                I will keep an eye out for .130 and clean it up after that release.
                This is a good solid plugin, and I am starting to use the response info to detect songs and so on as I play pandora.
                  Glad it helped work around the issue for now
                  Cheers,
                  Bob
