Is anyone else having an issue getting the plugin to work
  • #61
    this is what I see when I telnet into Master B/R TX=-NR626
    Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro
    • #62
      and here is what I see with Living Room ???? TR-NX737
      • #63
        Originally posted by Blade View Post
        What model are you using?
        Is it the same as gearyt?
        Nr737 same as one he's starting to test
        • #64
          this may be really dumb
          but the commands listed in the .ini file are the ones working
          by any chance, do I need to add more ??????
          • #65
            So those are working on the 737 too?
            Cheers,
            Bob
            • #66
              sorry, no... nothing on the 737 after I added the 636... For some reason, It doesn't like two, that's why I asked about the port assignment
              • #67
                What results are you seeing ?? My seemed to work like the 626 until I added a second receiver, then lost it..
                • #68
                  The receivers should have separate IP addresses so the same port of 60128 should work
                  Cheers,
                  Bob
                  • #69
                    and they do.... .20 and .22
                    • #70
                      Then I am confused why they both will not communicate using the same port. Attach your hspi_BLOnkyo.ini file zipped
                      Cheers,
                      Bob
                      • #71
                        sent my ini file, noticed over the testing, my CR option got mis-set
                        will probably fix it when I get home
                        • #72
                          From work, looks like I was my own problem
                          both receivers "appear" to be talking now
                          On to Input testing...
                          • #73
                            be home in a couple of hours.. but it looks like the learning curve for me is over.. need to do some PI config and device deletion to match my model and we are there...
                            • #74
                              Soo you are able to control 737? For me it will not receive any commands only status if manualy change something on receiver. I even loaded hs3 fresh onto another pc to test and same results
                              • #75
                                ok.. home again..
                                receiver 1 ( NR-626 ) is working to a point
                                inputs bounce arround, I think due to feature options.. will test more, but do something
                                panel dim/bright/ off = inop
                                Reciever 2 = no control.. will power cycle receiver and see what happens
