Setting Input via Event "warning"
  • Setting Input via Event "warning"
    I am getting this error when I try to set the input of an Onkyo 929:
    Nov-24 9:16:57 PM Warning Received unsupported SetIOMulti action for BLOnkyo Plug-In Device
    I am running version 2.0.16 and I have set the plugin to debug but that is all it is outputting.
    There will be a log in your HS root folder called BLOnkyo-Detailed.log
    Cheers,
    Bob
      I think I have it captured. I had to be quick or the file would get too large to attach.
      The warning in homeseer log came at 7:53:49 AM for a time reference.
        There is no error in the log.
        That message must have come from HS3.
        I am not sure what caused. What were u doing when that happened?
        Cheers,
        Bob
          Instead of creating a button in HSTouch to change the input of the onkyo I was going to create an event and assign the button to run the event.
          Then event was going to change input of onkyo, press play on the sonos, and some other things.
          When I manually initiate the event, the other steps do happen. It is just the Onkyo switching inputs that does not.
