installing 2.0.17.0
  • installing 2.0.17.0
    Bob,
    I don't get the status of the input setting working 100% ( they don't update all the time) so I figured I'd update the plugin.
    Version 2.0.17 is listed in plugin manager, but I can't install it because I'm not on HS 3 version 130. The last stable HS version is .96
    Will upgrade help me ? ( sorry, can't find the release notes of .17)
    If so, is there a way to install it on a stable version of HS ?
    Cheers,
    Frank.
    There was an issue with INI saving in older versions of HS3 that was fixed in 130.
    What version are you running now?
    Cheers,
    Bob
      I'm on 3.0.0.97
      I'll look for .130 and will try that.
      Cheers !
        Yep, with ..130, the .17 plugin installs fine.
        Issue is still there. If I switch one of the inputs to FM, the device string stays on Video1. It doesn't seem to be consistent. sometimes it does show FM, but I can not reproduce yet.
        Any clue ?
        Cheers,
        Frank.
          Try to capture it with debug logging on in the plugin
          Then create a help desk ticket on my site and attach the debug log zipped to the ticket
          Cheers,
          Bob
