installing 2.0.17.0
  • Blade
    Try to capture it with debug logging on in the plugin
    Then create a help desk ticket on my site and attach the debug log zipped to the ticket
  • fvr
    Yep, with ..130, the .17 plugin installs fine.
    Issue is still there. If I switch one of the inputs to FM, the device string stays on Video1. It doesn't seem to be consistent. sometimes it does show FM, but I can not reproduce yet.
    Any clue ?
    Cheers,
    Frank.
  • fvr
    I'm on 3.0.0.97
    I'll look for .130 and will try that.
    Cheers !
  • Blade
    There was an issue with INI saving in older versions of HS3 that was fixed in 130.
    What version are you running now?
  • fvr
    started a topic installing 2.0.17.0
    installing 2.0.17.0
    Bob,
    I don't get the status of the input setting working 100% ( they don't update all the time) so I figured I'd update the plugin.
    Version 2.0.17 is listed in plugin manager, but I can't install it because I'm not on HS 3 version 130. The last stable HS version is .96
    Will upgrade help me ? ( sorry, can't find the release notes of .17)
    If so, is there a way to install it on a stable version of HS ?
    Cheers,
    Frank.
