Device Status as Trigger?
  • Device Status as Trigger?
    I would like to use this plugin to set the ISF Day/Night mode on my TX-NR3007 based on the time of day. I added the ISF command and it works great when I manually run it as an event. So far. so good. Now, I would like to setup an event so when I turn the receiver on using my harmony remote, it will set the ISF mode based on the time of day. However, HS3 does not recognize the device power status when I set it as a trigger. Is there some way to make this happen? When I turn the receiver on or off, it does not register in the HS3 log.
