Tuner maintenance
  • Tuner maintenance
    Tuner maintenance is coming to BLRussound
    You will be able to add tuners to the plugin. Each tuner is set to a specific source. Each tuner will have devices which you can use to control the tuner
    Stay tuned
    Cheers,
    Bob
    Here is a screenshot of my tuner
    Cheers,
    Bob
      This is great Bob. I am starting to play with it.
      What does Tuning Mode (distant/local) do?
      So if I get it, I have an ST2 with XM (Source 1). On the ST2 it has bank 1 and bank 2 (each with 6) preset to various stations. So 1-1 is channel 3 (Venus). So I can setup a tuner for source 1 and it will allow me to change the presets in an event? If so, then the same would go for my AM/FM on source 2 (part of my CAM6.6.
      Michael
      HS3Pro on Win2012R2
      Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
      BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, NetCAM, PHLocation, Pushover 3P, Random, UltraLighting3, weatherXML, ZigBee, Z-Wave
        This is just adding a tuner, not an XM tuner - I may add those as well
        Tuning Mode
        Normal operation is in Distant mode. In cities, antennas can pick up multipath signals when they bounce off buildings and get doubled. The Local mode limits the noise associated with these reflected signals.
        Cheers,
        Bob
          Thanks. I look forward to having the XM too.
          What icons did you assoiciate with it as they came up blank when the devices were created.
          HS3Pro on Win2012R2
            The only icon I used was for the power status
            You could add your own if you wanted but they are really not needed
            Cheers,
            Bob
              Sweet
              Sent from my XT1585 using Tapatalk
