Hi Blade,
I am trying to make your plugin working with my controller - Russound MCA-C3, no luck so far.
My HomeSeer system is Hometroller Zee with latest HS3.
Here what I did:
1. Connected USB to RS232 cable from Zee USB to DB9 port in the back of the MCA-C3 controller.
2. Set up the plugin: created controller, set port to /dev/ttyUSB0, protocol - RNET
3. Enabled plugin
4. Tried to turn on one zone using plugin - On button was not reacting when I was trying to click it.
5. Tried to use different cable - same result
6. Switched protocol on both controller and plugin to RIO.
7. Now when I click on different buttons in plugin devices I can see that the status changes (i.e. when I click on Power On, it switches to On), however nothing happens in controller - zone remains Off.
I tried to put a detailed logging, but cannot get much out of it, see attached.
Not sure where to look or what to try next. Any advise would be appreciated.
Yuri
Here what I did:
3. Enabled plugin
Yuri
