.140 gives Error and zone not shutting off after BLSpeech
  • .140 gives Error and zone not shutting off after BLSpeech
    I am getting the following error in the log. I think I updated to .140 on the 22nd, but need to verify.
    Jan-22 17:50:03 BLRussound Error SetZonePowerNoQueue(): Command: 4 is not valid.
    I don't remember what I did that caused the issue but I have noticed with .140 I am back to having zones not return to previous source or shut off when BLSpeech finishes and I use a zone and not just a single speaker.
    Example. I have 3 rooms setup in a zone called SecondFloor. If something goes to BLSpeech with the source of 3 (speech proxy) for the second floor, all 3 rooms turn on, move to source 3, play the speech and then only 2 of them move back to previous source (in this case my ST2 and XM) and then turn off. The third room stays on source 3 and stays on.
    We had something like this before and found the plugin was sending to the CAM6.6 messages too fast and the CAM6.6 did not process all of them. Maybe this is happening again?
    Not sure what to do to capture this. I can do a debug log if that helps.
    Michael
    HS3Pro on Win2012R2
    Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
    BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, NetCAM, PHLocation, Pushover 3P, Random, UltraLighting3, weatherXML, ZigBee, Z-Wave
    None of the command processing changed at all
    Capture that in a debug log and attach it zipped
    Cheers,
    Bob
      Hi Bob,
      I turned on debug on the 7th and it happened again on the 9th at 5:00 PM. The debug log was 7 GB so using UltraEdit I was able to remove everything from start to 4:45 PM on the 9th and everything after 5:40 PM. I zipped the file and even at only 5 MB it fails to upload. Let me know if I can Dropbox it to you or upload it to your site or something.
      There are a couple events that happen at 5 PM to 3 zones. After they finish the zones do not go back to the source they were on (source 1) but stay on source 3 and zone 1 does not turn off.
      Let me know if I need to add anything.
      EDIT: opened 1107 on your help desk and attached the zip there.
      Michael
      HS3Pro on Win2012R2
      Unconfigured PHP Module
