Ignoring power on volume
  • Ignoring power on volume
    It seems like this used to work, but does not now. I have power on volume set for a zone (only have 1 set up right now) on my CAM6.6. Regardless of what power on volume is set to, if I power off a zone and power it back on the volume is set pretty high. I don't know what level it's actually set to, because the plugin devices show that it's set correctly to the power on volume.
    HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
    Hardware: Z-NET - W800 Serial - Digi PortServer TS/8 and TS/16 serial to Ethernet - Insteon PLM - RFXCOM - X10 Wireless
    Plugins: HSTouch iOS and Android, RFXCOM, BlueIris, BLLock, BLDSC, BLRF, Insteon PLM (MNSandler), Device History, Ecobee, BLRing, Kodi, UltraWeatherWU3
    Second home: Zee S2 with Z-Wave, CT101 Z-Wave Thermostat, Aeotec Z-Wave microswitches, HSM200 occupancy sensor, Ecolink Z-Wave door sensors, STI Driveway Monitor interfaced to Zee S2 GPIO pins.
    Can you try and capture this in a debug log and attach it zipped
    I will try and duplicate that here on my CAV66
    Cheers,
    Bob
      Thought problem was solved, but is not. Gathering logs.
        Debug log zip file is pretty large so Dropbox link is here https://www.dropbox.com/s/ckb3d8i6wi...ailed.zip?dl=0
        Here are the steps I took to test:
        1. Stop plugin, delete log file, Restart plugin
        2. Set turn-on volume for C1 Z3 to 12
        3. Power off C1 Z3
        4. Power on C1 Z3
        5. Volume levels are displayed correctly in device management (volume and turn-on volume at 12), but zone is actually playing at the previously set turn-on volume.
          Did you zip the debug log? I have found that they compress to incredibly small sizes.
          Originally posted by rprade
            It was about 650K zipped. I figured Rupp would appreciate not having that stored in the message board.
              I just tried this here on my CAV66 and it seems to work
              I changed the turn on volume to 22 on the device management page using the slider for the turn on volume device. I then powered on the zone and it changed the volume from 18 to 22 which I would expect
              I powered off the zone, changed the turn on volume to 18 and then turned on the zone and it changed the volume to 18
              Cheers,
              Bob
