RS232 Not working
  • RS232 Not working
    I have two controllers. A CAM6.6 and a CAV6.6 The CAM is working fine when connected to the hometroller S6 but if I connect the CAV nothing works. I am new to these so not sure how/what to check.
    Kirk
    http://cleverhouseautomation.ca
    http://southcoastwebsitedesign.ca
    Do you have serial connections to each Russound? Or maybe they are linked together via an Ethernet cable, with a serial connect to only one device... I would go into the programming of the Russounds to see for sure that they are set to different device #'s.
    Have you connected ONLY the CAV and there is not communication?
      Disregard this. I just got back from where these are and as I was driving over there I thought I would check to make sure that the switch on the CAV was on the back position.... It was not. Once I fliped it over, everything worked
      Kirk
