Ethernet to serial bridge?
  • Ethernet to serial bridge?
    Hello -
    I have the plugin working well using a direct serial port but I need to use a ethernet to serial bridge. I have the bridge setup to listen on port 2002, but when I put the IP + port into the plugin, it doesn't work. I was using the format of 1.1.1.1:2002. Is this supported? How can I get this working?
    Also, is there any support for manually setting the Target ID in the plugin? I faked it (as my device is ID #3) by adding 3 controllers and removing the first 2, but wondering if there is any supported way to do this.
    -Justin
