BLRussound process does not terminate
    I assumed this was not an unknown issue, but at Rupp's recommendation I want to be sure I am not making an unwarranted assumption.
    When I disable BLRussound its process does not reliably terminate. To install an update I need to kill the process with Task Manager. (If I do not kill the process before re-enabling the plug-in I see two copies of the process running in Task Manager.)
    I also notice that the process takes a long time (many minutes) to terminate when I close HomeSeer. In fact it appears that HS has to kill the process in order to complete the shutdown process.
    This plug-in is not the only one that behaves this way, and it's a minor nuisance, but I suppose it may point to an underlying problem.
    Try out 2.1.12 in the beta section
    Cheers,
    Bob
      v.12 terminated immediately after disabling it. Thanks.
