I had this set up a long time ago and tried using a serial to ethernet adapter to no avail. So I'm going to back to serial now and I can't remember my settings. None of the 2 ports matched with any of the 3 serial options seem to work.
In addition, I tried to turn on debug logging so I could see what the plugin was doing, but all I get is this:
02/14/2021 04:31:55:617 PM : v2.1.34.0 - **************** Debug Logging DISABLED at 2/14/2021 4:31:55 PM ****************
I will only say enabled in the HS log when I disable it, then I get an enable and disable message right after each other (thoug there is a good almost 30 seconds between those messages, I for some reason never see the enable message until I disable logging):
This is on HS3 on Windows server 2016 Essentials.
Feb-14 4:30:09 PM | BLRussound Info | BLRussound Debug Logging Disabled! |
Feb-14 4:29:42 PM | BLRussound Info | BLRussound Debug Logging Enabled! |
