Blade, I curenltly have the plug-in installed and connected to the MCA-C5. I've only tested zone power on/off which seems to be working. I haven't messed with scripting volume controls etc yet (learning curve for me). Question, can the plugin be updated to support the zone 7 and 8 of the MCA-C5?
MCA-C5 Supported - Now works!!
Originally posted by Sireone View PostBlade, I curenltly have the plug-in installed and connected to the MCA-C5. I've only tested zone power on/off which seems to be working. I haven't messed with scripting volume controls etc yet (learning curve for me). Question, can the plugin be updated to support the zone 7 and 8 of the MCA-C5?
The other options should work if those work but test them out.
Please add a feature request for zone 7 and 8 on my web site for this.
Have you been able to test the other functionality?
I currently have the Speakercraft system (mzc-66)and I can control everything with my iphone. It would be excellent if there was a plugin for that to integrate with Homeseer but there is not.
Per the russound web site, only the MCA-C3 and MCA-C5 series of multiroom audio controllers. If they do not work seamlessly with homeseer, then I am hesitant to upgrade particularly with the cost.
Yes, based on Blades scripting methods, I've been able to power on/off all 8 zones, switch sources and control volume. One thing I'll point out however, is that zone 7 & 8 are pro out and for some reason, I cannot control the volume of those two zone. I am using a R850MC amp which could be the difference. One other thing, the status page doesn't seem to reflect the actual status of the controller. Example below, the 'Turn on Volume' (below) is not 494. Also, if the unit is controlled via the Russound iPad app, or a keypad, the status screen is a bit off as well. Other than that, it seems to be working for basic functionality. I do wish we had controls for the volume, bass, treble etc on the device management page though. I've put the the request, so it shouldn't be long.
Update!!!!
With the countless hours working with Blade, I can now confirm that the Russound MCA-C5 (And C3) is now fully supported! I'm able to control all aspects of ALL zones via the HomeSeer status page and via scripts including controlling the volume, bass and treble. Again, thanks Blade for awesome work you do with HomeSeer.
-Devon
Originally posted by Sireone View PostWith the countless hours working with Blade, I can now confirm that the Russound MCA-C5 (And C3) is now fully supported! I'm able to control all aspects of ALL zones via the HomeSeer status page and via scripts including controlling the volume, bass and treble. Again, thanks Blade for awesome work you do with HomeSeer.
CJ
Originally posted by cjr18 View PostThis is great news!! I currently have three 8 conductor wires running from the MCA location to the server location. Anyone have advice on where to find a good DB9/serial wiring guide and where to purchase the connectors? I'm ready to hook up the MCA now that this plugin is compatible.
CJ
Code:3.1 COM Settings The following settings must be made to the RS-232 serial COM port used to interface with the Controllers: • 19200 baud rate • 1 Start bit • 1 Stop bit • No flow control • No parity 3.2 Connector Type / Pin-out Connector: Female DB-9 6 • Pin 1: NC • Pin 2: Transmit • Pin 3: Receive • Pin 4: NC • Pin 5: Ground • Pin 6: NC • Pin 7: NC • Pin 8: NC • Pin 9: NC
Finally made the necessary RS-232 connection. Thanks for the info.
Since installing the plugin, running HS3 as a "user" now prompts a UAC for registry change "MSCommControl.reg". Clicking "Yes" allows the startup to complete and everything works well. Interestingly, when I instead choose to run HS3 as "administrator" the reg UAC does not appear, but the "com1 is open" message does not appear in the startup log and (obviously) the commands do not work.
Thanks for your help; I'm happy to help with any MCA-C5 testing required.
CJ
HS3PRO 3.0.0.152; BLRussound 2.0.50.0; MCA-C5 (latest firmware)Last edited by cjr18; February 13, 2015, 02:25 PM.
Originally posted by cjr18 View PostFinally made the necessary RS-232 connection. Thanks for the info.
CJ
Originally posted by Sireone View PostI'm noticing the same thing on the Status page of the Russound. Whenever I need to see it in real time, I just click the Status button again. Not seeing that issue about UAC as I disable it on my Windows 7/2008 boxes.
Also, I've thought of disabling UAC, however I would prefer to keep it on as an extra layer of security.
Not working for me
I had demo'd the plugin a while back and i think everything was working properly. I just purchased the plugin, and now nothing seems to be working. All the zones are populated with the correct names, so there must be some sort of communication happening, but my MCA-C3 and its controllers don't respond to any commands from Homeseer. I do have the Com Port Control Type set to "Homeseer". I don't have anything int he "Russound com port" field though - is this necessary if it's all working over IP?
