Plugin Stopped Communicating
  • #16
    It is likely a comm issue. The plugin installs the .reg file needed when it starts. Make sure you are an admin user when starting HS3
    If still an issue then attach a BLRussound debug log zipped of the startup of the plugin
    Cheers,
    Bob
    • #17
      Debug of adding a controller and viewing the status.
      https://onedrive.live.com/redir?resi...int=file%2clog
      Using this serial device which shows up as Com3 in Windows Device Manager:
      http://www.amazon.com/gp/product/B006PIU2KO
      Using these options:
      https://onedrive.live.com/redir?resi...nt=photo%2cPNG
      Status in plugin config show all off (when half are on):
      Status for Controller #1 - Home
      Zone #1 Zone #2 Zone #3 Zone #4 Zone #5 Zone #6
      Name Zone 1 Zone 2 Zone 3 Zone 4 Zone 5 Zone 6
      Power OFF OFF OFF OFF OFF OFF
      Source 0 - 0 - 0 - 0 - 0 - 0 -
      Volume 0 0 0 0 0 0
      Muted OFF OFF OFF OFF OFF OFF
      Background Color
      Turn On Volume 0 0 0 0 0 0
      Treble
      Bass
      Balance
      Loudness OFF OFF OFF OFF OFF OFF
      Do Not Disturb OFF OFF OFF OFF OFF OFF
      Party Mode OFF OFF OFF OFF OFF OFF
      Party Mode Master OFF OFF OFF OFF OFF OFF
      Shared Source Not Shared Not Shared Not Shared Not Shared Not Shared Not Shared
      Front Aux Input OFF OFF OFF OFF OFF OFF
      This is one of two issues delaying my conversion from Vera to HomeSeer (the other is Leviton Scene controller support).
      • #18
        Can you change the com port to just 1 instead of Com1
        If still an issue then attach a new debug log
        Make sure to delete the old debug log first
        Cheers,
        Bob
        • #19
          That is already the current setting, albeit Com3 which I just have #3 per this screenshot:
          • #20
            Change the com port type to MSCommLib and save.
            Then restart HS3
            Let me know
            Cheers,
            Bob
            • #21
              Awesome! I'm now able to control it with MSLib
              The bad news is still can't get the status. Unless control is changed from HS, it seems it doesn't know the status of the current zones.
              Is this normal? On the Vera, I was able to detect this on Vera (and make events fire if sound turned on/off via the wall panel Russound remotes in each room).
              Log:
