Some issues installing
  • Some issues installing
    I have 2 MCA 88's - on COM7. I configured the plugin to use extra zones and it seems to be connecting fine - in debug mode I see messages being sent/received to the Russound.
    The issue is the devices created in HS - the first 6 zones have no control options only the last 2 do.
    Also, the created devices don't seem to be grouped like I see in other posts - meaning, c1z7 devices are not together.
    Can you try restarting the plugin
    Cheers,
    Bob
      Yeah - I did that. I also restarted machine too...
      I also have Main Lobby Russound plugin disabled - it was working there but thinking strongly moving to HS...
        That is odd.
        Can you do the following:
        1. Disable the plugin
        2. Edit the hspi_BLRussound.ini file and change debugLevel=true
        3. Save INI file and close it
        4. Re-enable plugin
        5. Once started for a minute disable debug logging
        Attach the BLRussound-Detailed.log file zipped from the HS3 root folder
        Cheers,
        Bob
          Enclosed - thanks for the help.
            I will have a look as soon as I can
            Cheers,
            Bob
              Try the following:
              On the options page change the com port type to HomeSeer and save
              Then restart the plugin
              I will check into the grouping. It is strange because when I setup mine a month ago it grouped them. Will let you know
              Cheers,
              Bob
                I did that, restarted. Now, I have zone 7&8 on both Russounds looking OK - grouped, with buttons to control but zone 1-6 on both units are not grouped and no buttons like I posted before. Something strange is going on with the first 6 zones... Thanks.
                  OK Can you log a ticket on my web site
                  Attach the log you attached here - this way I can track this easier
                  I will check the code when I get home today and see what is going on
                  Cheers,
                  Bob
                    Done - thanks for the help.
                      One thing you could before I take a look
                      Disable the plugin
                      Delete all deletes associated to the plugin
                      Enable the plugin
                      It should create all devices again
                      You need a restart of the plugin after this
                      Cheers,
                      Bob
                        Did that - same result - it created zone7&8 OK - Zone 1-6 still not correct.
                          Ok will have a look and let you know
                          Cheers,
                          Bob
                            Try 2.0.105 in the updater
                            Cheers,
                            Bob
                              Looking great! Everything grouped, buttons for all - I am traveling this week so I won't be able to actually use it until this weekend so I will give more feedback then. But, all looks good to move forward - thanks!
