I tried to enter "8" in the number of active sources and it resets back to 6 -- can this be increased to 8 for the MCA units? Thanks.
Support for 8 Sources?
Yes - so far so good. I am now working on moving control of my Russound from ML to this plugin - to date, I have only tested power, volume and some of the basic controls using the device interface buttons but everything I tried so far works well. I also see the two-way working fine too - turning on a zone instantly shows on in the device. It will take me some time to complete the transition as I have a lot of control still built in ML. My motivation is that I am trying to make ML have no plugins and simply be a graphic front end to HS - I find the plugins in ML really drag down the performance of the ML interface, at times stalling the server where it becomes unresponsive for short periods of time - The only plugin left that I can't replace in HS is Yamaha -- I see you have a plugin request for this so +1 here to get a Yamaha plugin! Thanks,
