2-way status doesn't seem to work...
    No problems controlling the Russound with the plugin now - but when I go to a keypad and change the source or change the volume, the associated device in HS doesn't change value. But, power does work perfect which is strange. If I press power on the keypad the status in HS updates instantly...
    I enclosed a log where on Unit 1, Zone 6 I went to the keypad, changed the volume and the source - both actions did not change the associated device in HS.
    Make sure the com port type on the options page is set to HomeSeer
    Cheers,
    Bob
      It is - thanks,
        What controller?
        Cheers,
        Bob
          Controller unit 1, zone 6 - both controllers are MCA-C5's.
            Ok I will check the log
            Cheers,
            Bob
              The MCA-5 is returning events differently than my CAV66
              I will have to look into this one
              Cheers,
              Bob
                I think my issue is related/similar.
                I have a MCA-C5 as well and am testing this plugin.
                Most control things are working (vol/sources etc) but being able to trigger an HS event from a Keypad would be a huge plus but it doesn't seem to be working with my C5. Is there a particular device type that I need to set in the Russound for this to work or is this a MCA C5 issue?
                I want to use the keypad buttons like next to trigger the next song from my JRiver media player (PC based)
                  I have tested the F1, F2 and power button triggers in HS and they seem to work fine for me. The only known issue I have is the status in HS changing if I manually change the source or volume on the KP. I have only implemented triggers on power, F1 and F2 so I am not sure my findings are complete...
                  Looking forward to see if the volume/source issue can be worked out.
                    Hi Blade - any luck on figuring out those extra messages?
                      Not yet sorry
                      Cheers,
                      Bob
                        OK - happy holidays! Thanks for your great plugins and support.
