Cannot set DND from plugin
  • Cannot set DND from plugin
    Using HS3 and BLRussound 2.0.109.0 with a CAV6.6.
    It looks like the plugin is not setting the Do Not Disturb mode on the zones. On the wall panels DND is never lit, and pages are still heard. If I go to the wall panel and turn DND on from there, the function in the CAV works (DND lit and pages blocked) but HS still shows DND as 'off'.
    When I turn DND on from HS, In the logs I see the message go to the CAV - there is a HANDSHAKE received but no DATA.
    Dec-04 4:22:40 PM BLRussound Message Rcvd --- [HANDSHAKE] F0 00 00 71 00 00 7F 02 02 6D F7
    Dec-04 4:22:40 PM BLRussound Message Sent --> [Set Do Not Disturb] [C: 1 Z: 1] F0 00 00 7F 00 00 71 00 05 02 00 00 00 00 06 00 00 00 01 00 01 00 00 06 F7
    Dec-04 4:21:57 PM BLRussound Message Rcvd --- [HANDSHAKE] F0 00 00 71 00 00 7F 02 02 6D F7
    Dec-04 4:21:57 PM BLRussound Message Sent --> [Set Do Not Disturb] [C: 1 Z: 1] F0 00 00 7F 00 00 71 00 05 02 00 00 00 00 06 00 00 00 01 00 01 00 01 07 F7
    Dec-04 4:21:28 PM BLRussound Message Rcvd --- F0 7E 00 71 00 00 7F 05 02 01 00 02 01 00 F1 37 00 00 00 01 00 00 28 F7
    Dec-04 4:20:25 PM BLRussound Info BLRussound Debug Logging Enabled!
    If I turn on/off Party Mode, I see a DATA response as well as the handshake, and the wall panel 'party' and 'master' indicators are on/off as appropriate. In fact all other functions through the plugin appear to be working properly, its just DND that isn't working.
    Is there anything else I should be looking for?
    Geoff
    Just noticed 2.0.119 was available for update - it seems to have fixed this issue.
    Will do more testing over the weekend when I can annoy everyone with test pages
    Cheers,
    Geoff
    Unconfigured PHP Module
