What is Use Condition?
    Bob,
    in the Speaker config in BLSpeech, it has "Use condition". If I check it it gives me the chance to select a device and provide a value, but the help site doesn't say what this does.
    Edit: I'm hoping this is to allow us to control speakers in zones based on occupancy.
    MeiAutomtion Home
    If you select it, it will allow you to choose a device and a matching value for the device or else the speaker will be ignored
    So you could choose an occupancy device and enter in the value you want it to be equal to. If the condition device value is equal to what you specify then the speaker will process
    Cheers,
    Bob
      That is awesome! Thanks, Bob!
      Sent from my XT1585 using Tapatalk
      MeiAutomtion Home
        Bob, I have a question. Can I create 2 "speakers" with the same Russound "Relay/zone"?
        I'm not sure I would ever use this, but I have an idea, and I was just curious if I could do this (basically, I would create 1 that uses occupancy, and 1 that doesn't, but they would be the same zone in my russound...i.e. Foyer (3)).
        MeiAutomtion Home
          Hmmm I am not sure what that would do
          Worth a try I guess - I guess if you called on them independently it should
          Cheers,
          Bob
            So I can't get "use condition" to work. I ran a test this morning.
            I took my guest bathroom "speaker" and I checked "use condition". I then selected my guest bathroom occupancy device (0 - unoccupied; 100 - occupied) and set the value to 100 (I also tried 0 (zero) in case it was backwards).
            I then went to my "whole house" zone and checked "use conditions". After that I just ran a test event that I use for testing speech. It still played in that room.
            I will PM you my log.
            Edit: I guess you can't PM attachments. If the log has no personal info, let me know and i'll post it here, or I'll put in a bug on your site if you like.
            MeiAutomtion Home
              Email me the debug log directly for it
              Cheers,
              Bob
                Resolved in 2.0.61
                Cheers,
                Bob
                  So, this does in fact work. I had an instance where I always wanted a speaker to do a specific announcement (the turning off of the automatic lights in the guest bathroom), but be conditional other times. So I just created another "speaker" and added (nc) (No Condition) to the end so I would know which one to use.
                  I then just put speaker=Guest Bathroom (nc) and it worked
                  This allows me to create speaker and zones where I can have the flexibility to force a speaker in some instance and use a condition in others
                  MeiAutomtion Home
