“Log to file” wasn’t on. It is now and it now seems to show entries on the activity page.
I though log to file was a separate thing and another way to keep a history. Maybe the option to enable logging could be put on the activity page?
Could you make parts disappear when it needed. For example the activity page is off if the option isn’t on
And the “special processing tag” page not available if there are no devices added etc?
BLSpeech 4 issues
Hmm that is odd because mine is showing fine here
Does BLSpeech-Activity.log exist in the [HS root]\Data\BLSpeech folder
Thanks - let me know if you need anything from me. Feel free to direct message me if you use Skype/Whatsapp etc and you need info.
For the special processing tags (speakers and zone)... it will show the speakers and zones you have added to the plugin - NOT the speaker clients in HS
I will check the activity log and queues
The actions page now works in the 4.0.1 beta
However, I still can't see anything in the activity log.
Also if i set the "Speak Proxy Mode" to away and send some speech, it doesn't play (which is correct), but it doesn't show in the queue page, and when i take out of away mode, it doesn't play.
Also still nothing in the special processing tag selections..
For information, I can see the list of my speakers under "Speaker Client to use as main speaking client" on the "Speaking" tab
