When you define a script to be executed prior to speaking, is there a way to obtain the text that is about to be spoken? I see there is a method to access the tags and assuming it would be the tags for the message about to be spoken, but I didn't see anything to access the text. This scenario is obviously dependant on setting 'wait for script to finish before continuing' option so you have time to access the current TTS message.
Question
Question
HS: 2.5.0.60
Environment: Virtual XP as guest in VMWare Server running under Win 7
Plug-ins: MLHSPlugin|RCS Serial Thermostat|UltraLog|UltraMon|
Misc: 303 Devices, 313 Events, 68+ Scripts
HSeer: 3.0.0.54
Plug-ins: BLGData|BLRF|BLRadar|BLRandom|BLSpeech
UltraM1G3|UltraECM3|UltraMon3|UPBSpud|Z-Wave
Misc: 148 Devices, 116 Events, 9+ Scripts (so far, still converting)Tags: None
Done! Thanks for your consideration on this. Short story is, this would allow you to take all spoken text and forward it to beta brites or other devices.HS: 2.5.0.60
HSeer: 3.0.0.54
Thanks, will give it a try!HS: 2.5.0.60
HSeer: 3.0.0.54
