Blade, for some reason when I have an event speak using BLSpeech (image below), It will turn the zones on (in All Rooms), speak the phrase, then set zone 8 to Tuner (originally set to PC). All zones are also left on. This makes no difference if I have the "All Rooms|Off" in the tag. So basically, it's not adhering to the BLSpeech setting "Russound Zones Return to the Original State After Speaking". I can send you the Debug log when you want. Thanks again.
-Devon
-Devon
