Determine Away mode?
Originally posted by Blade View PostTry 2.0.22 in the HS3 updater
I have added the "GetProxyMode" scripting call.
You and Spud (with some Kinect modifications) are my heros!!
Hi Blade,
Just getting feet wet with speech. If I'm in Away mode, I would like instead to send messages automatically to an email address.
So, I was thinking that this could be done by setting the Speech Proxy mode to Away. I could write a small script to be executed post-speech (which I'm assuming would still be fired, regardless of Speech Proxy mode). The script could determine whether I was in Away mode, and if so, retrieve the text and email it instead.
However, I don't see a scripting method available to test for Speech Proxy mode. I see SetProxyModeNormal and SetProxyModeAway, but no GetProxyMode type function.
Is such a function available, or is there another way to either test for Proxy mode or to do what I'm describing?
hjk
