OK. It's a done thing.
Is it possible to have profiles or some such?
Originally posted by Blade View PostBUT if you want to send the same speech message again but specify the "speaker" tag then you would have to use the hs.Speak command with something like this:
I'm not following you on this. What is it that you mean by "send the same speech message again but specify the "speaker" tag"?Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Originally posted by Blade View PostIt just means you could pass any other tags you want into the handler code and it will process them as s new speech messageOriginally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Yeah. The latest update made my system not respond to the Sound special tag. The Speaker, Source and Volume tags are still honored. I haven't tried the zone tag yet though. I don't use that one much.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Originally posted by S-F View PostYeah. The latest update made my system not respond to the Sound special tag. The Speaker, Source and Volume tags are still honored. I haven't tried the zone tag yet though. I don't use that one much.
You just put a sound clip somewhere (maybe it has to be .wav? I forget) and point to it in BLSpeech and give it a title.
So, in BLSpeech, got to Sounds -> Add New and then give it a "Short Name" which the special tag will use to call it and then enter the full path (as in windows directory structure) to the sound. If you don't have a sound I am more than happy to zip one up here and attach it for you.
So for example, I have much of my TTS prepended with a chime that some good soul on the board ,whose identity currently escapes me. So in the list of special tags I just add "Sound=Chime" since "Chime" is the name I gave it in the Short Name field.
Oh Hell. I'll just upload it right now in case you or anyone else wants it.Attached FilesOriginally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
