No Stations
  • No Stations
    I've been trying to get this working...I've installed several times going step by step with the video.
    It appears that I don't have any stations to load
    I've opened a ticket #818
    List what DLLs are in the HS3 root folder
    Cheers,
    Bob
      FTD2XX_Net.dll
      HomeSeerAPI.dll
      hsaudio2.dll
      HSCF.dll
      Insteon.dll
      Interop.hsrecord2.dll
      Interop.WMPLib.dll
      RssToolkit.dll
      Scheduler.dll
      taglib-sharp.dll
        Updated the help ticket.
          It must have to do with the lineup you are selecting.
          Have you attached a debug log to the ticket. I am not at home to check
          If not do the following:
          1. Shutdown HS3
          2. Edit hspi_BLTVGuide.ini and change debugLevel=true and save INI file
          3. Restart HS3
          4. Once started for a minute and the initialize is done, try and bring up the add lineup page.
          5. Then turn off debug logging and attach the BLTVGuide-Detailed.log zipped to the ticket
          The log is in the HS3 root folder
          Cheers,
          Bob
            Latest log is the zip file.
            I know data is being downloaded since I can see the 2 xml files in the data directory.
              What lineup are you using?
              I have seen a couple others with the same error in the log. There is a null somewhere in the received data. I need to find where it is coming from.
              Will let you know
              Cheers,
              Bob
                USA-DITV641-DEFAULT
                This is the Direct TV for San Antonio
                Do you want me to attach the xml files to the ticket?
                  Any updates for me to try?
                    I posted a new build a couple weeks ago
                    Do u have the latest build from the updater?
                    Cheers,
                    Bob
                      Yes, I saw that release and tried it but I still get the same results.
                        OK then i need a new debug log of an initialize?
                        From what I remember it seems to be getting your data
                        Attach it to your ticket on my site if you have one. If you do not have a ticket then please create one and attach zipped
                        Cheers,
                        Bob
                          Also load the stations page too with debug logging on
                          Cheers,
                          Bob
                            Tried to upload BLTV20150903.zip twice and get the following message once it hits 100%
                            Active Server Pages error 'ASP 0113'
                            Script timed out
                            /helpdesk/AddAttachment.asp
                            The maximum amount of time for a script to execute was exceeded. You can change this limit by specifying a new value for the property Server.ScriptTimeout or by changing the value in the IIS administration tools.
                            Script timed out
                            I should also note that when I turned on debugging, I received the following error in HS3 logs (3 times)
                            Sep-03 17:50:06 BLTVGuide Error DetailedFileWriter.WriteDetailedLog(): Caught this exception - Object reference not set to an instance of an object.
                              schedules direct site looks like it is down right now
                              Cheers,
                              Bob
