No Stations
Yes it only seems to be directtv causing the issue.
I am pretty sure it is because of the channels that look like this: 100-2
It is the dash that is messing things up.
I know the TV season is starting this week. Reply to your ticket on my site and remind me to look at this today. This will send me an email reminder
What can I do to help you solve this problem? It appears to only be on the Direct TV listing.
I see the 3 errors too. I will find the issue
I do not see the log attached
New zip file uploaded. I also went to the channels page before I closed out the debug logging.
I still get
Error DetailedFileWriter.WriteDetailedLog(): Caught this exception - Object reference not set to an instance of an object.
3 times when I turn on debugging.
Tried to upload BLTV20150903.zip twice and get the following message once it hits 100%
Active Server Pages error 'ASP 0113'
Script timed out
/helpdesk/AddAttachment.asp
The maximum amount of time for a script to execute was exceeded. You can change this limit by specifying a new value for the property Server.ScriptTimeout or by changing the value in the IIS administration tools.
Script timed out
I should also note that when I turned on debugging, I received the following error in HS3 logs (3 times)
Sep-03 17:50:06 BLTVGuide Error DetailedFileWriter.WriteDetailedLog(): Caught this exception - Object reference not set to an instance of an object.
OK then i need a new debug log of an initialize?
From what I remember it seems to be getting your data
Attach it to your ticket on my site if you have one. If you do not have a ticket then please create one and attach zipped
I posted a new build a couple weeks ago
Do u have the latest build from the updater?
