Originally posted by joegr
View Post
use Arduino As uirt?
But I don't need to use your script to get stuff working I can just use drhsIpPlugIn and usb-uirt plugin?
It was one I had in my parts bin from who knows when. Probably something like this: https://www.amazon.com/Infrared-Rece...no+ir+receiver
I have posted some barely documented code here: https://github.com/joegr123/ESP8266-IR-UDP
It is specific to me, so it will all have to be modified. Think of it as a possible starting point.
i like this idea... I'm starting to look into how to replace a Pronto TSU9600
Devoir
Originally posted by Daarn View Post
That sounds very nice. It evering I has looking for. will you share the code for the MCU? and what IR part you use?
Maybe also have you have setup you event in homeseer?
Can you PM me your email address?
Originally posted by joegr View Post
I've been using one (node MCU) for almost a year now to do just that. It receives and decodes IR and transmits IR. It works quite well. I have it communicating UDP and am using the drhsIpPlugIn to communicate from it to HomeSeer. I have receive events in HomeSeer to toggle room lights and lamps on and off, and to trigger IR out to help set up the AVR, TV, and Dish box.
One of the cool ones is this. If it is after a certain time at night and it goes more than 30 minutes since an IR command is received, it turns the TV/Dish/Avr off if they were on. It's an intelligent sleep timer of sorts.
THx For the input. Have you done any update? to see if you can receive?
can you also send the code?
Originally posted by Black Cat View PostYou can use a Z-UNO for this purpose. Arduino smarts with native Z-Wave.
http://z-uno.z-wave.me/examples/rs-485
I forgott about this thread
Originally posted by mrhappy View PostYou can also use a ESP8266 and an IR LED if you need transmission (not sure it works on receive), I built one unit for virtually nothing and have a LAN IR module.
- Likes 1
- Likes 1
