BL USBUIRT Win 10 issue
  • BL USBUIRT Win 10 issue
    Hi,
    I migrated my Win7 box to a new Win10 box, however i have an issue with my USB UIRT plugin since.
    I installed USBUIRT with the win7 64bit driver from http://www.usbuirt.com/support.htm
    Driver states its functioning fine. however when I start the plugin it, states;
    nov-27 11:53:44	 	Error	Initializing plug-in(1): BLUSBUIRT Instance::Unable to communicate with USB-UIRT device! Please check connections and try again. If you still have problems, try unplugging and reconnecting your USB-UIRT. If problem persists, contact Technical Support
    i triedconnecting and disconnecting and other drivers with no succes. Any ideas howto solve this issue?
    Bart
    Regards Bart
    Win7 64Bit on Intel NUCI7 with SSD
    HSPRO 3.
    Devices; 1370 Events; 691
    Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
    Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
    HI,
    Problem is solved, after reinstalling windows 10 completly and again installing the official drivers from USB UIRT website.
    regards
    Bart
    Regards Bart
    HSPRO 3.
      to early,
      and again, the plugin cant connect to the usb uirt. Using the official 64bit drivers, and the device showing up in the device manager without any issues.
      Anybody had an idea howto resolve this?
      Bart
      Regards Bart
      HSPRO 3.
