Hi Bob, thank you for making this plugin available;
I managed to use the interface with lrnhelper in order to manually input existing Hex Pronto codes.
However, Since I already have a large list of Hex Pronto codes + new ones easily available from multiple sources, I'd like to enter the codes directly in the hspi_BLUSBUIRT.ini file.
It was easy to figure out the ini structure:
[Device=unique HS device code]
key=unique HS key code
name= device name
then
IRCode_000x=device_000x~key~~x~devicename~SIGNAL~otherdetail s?~zone?
however, it seems like the SIGNAL part is slightly different than the Pronto code I enter in lrnhelper:
Pronto Hex entered in lrnhelper:
0000 0067 0000 0023 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0020 0010 0020 0010 0020 0010 0020 0010 0020 0010 0020 0010 0020 0010 0010 0010 0010 0020 0020 0010 0020 0010 0020 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0020 0010 0020 0010 0020 0010 0020 0010 0010 0010 0234
ini file output:
IRCode_0001=D20191207T115446249_0001~D20191207T115446249~~1~ TEST~F3ER00003020101010101010101010101010102010201020102010201020 102010201010101020201020102010201010101010101010102010101010 101010201020102010201010108234~1900032AA8EA~0
start and trailing parts are modified but can't figure out the conversion path.
Would you mind helping me out as it will considerably shorten the time required to input 100's of codes. I will then build a table that automatically populate the repeating data and add the Pronto codes. will then import in the ini file.
PS: if a "manual code input" could be added that would be even better =)
Thanks in advance, much appreciated.
Yann
name= device name
then
ini file output:
Yann
