Same kind of question here. I have a USBUIRT interface/device and would like to connect it to HS4 on Raspberry Pi 4b... there IS an HS4 IR plugin: IR PLUGIN (version 4.0.0.1 so it must have been around for a while) and I used to have a BLUSBUIRT plugin in HS3 (which is not available for HS4 on the Pi)... are these two plug-ins the same? Has anyone successfully connected the USBUIRT to HS4Pi using the IR PLUGIN? (And how did you do it? I keep getting errors...)
