** BLUSBUIRT is live **
This is a sticky topic.
  • ** BLUSBUIRT is live **
    The BLUSBUIRT plugin is now in the HS3 updater.
    You will need the following hardware in order to use this plugin
    http://www.usbuirt.com/
    Feel free to play with it and let me know.
    I am sure you will find issues.
    Please my help desk for issues.
    NOTE
    I also want to thank Jon Rhees for giving me his source code for this so that the plugin could live on in HomeSeer 3. Thanks Jon!!
    NOTE 2
    When learning codes, the learn window will always show behind the web page the first time. After the first time it seems to show in front. No idea why yet.
    Cheers,
    Bob
    Good job on this. Now how about a CM15A USB plugin
    -Rupp
      Greg,
      Does the HS2 source exist somewhere? If so I could convert it
      Cheers,
      Bob
        Thanks Bob, this gets me really close to being able to move my HS2 to HS3. Just need to verify compatibility with my version of RFXCom Receiver with current RF plugins for Temp Sensors. Its an older model running on USB and I think this may be a problem. Also have a dual band WGL-800 for wireless X-10.
          The W800 will work with my BLRF plugin but the old RFXCOM receiver will not.
          The old RFXCOM will work with the RFXCOM plugin. I am using it in HS3 and it works great.
          Cheers,
          Bob
            Perfect, thanks for that information. Now I just have to figure out the new events engine.
              Build 2.0.2 is in the updater
              In this build you can create event actions to send IR codes.
              Cheers,
              Bob
                registry
                I am a ways off before I use HS3 but are the IR codes for the urit still being stored in the registy?
                John
                  No they are stored in an INI file
                  Cheers,
                  Bob
                    Cut n paste from registry or a redo.....
                    Thanks so much for your efforts much appreciated....
                    HS3 Pro Edition 3.0.0.435 (Windows 10 vmware)
                    BLOccupied:,UltraNetCam3:,weatherXML:,RFXCOM:,Current Cost 3P:,UltraGCIR3:
                    DMMQTT:,Kodi:,Z-Wave:,BLRadar:,EasyTrigger:,MySensors:,BLBackup:
                      U will have to redo the learning.
                      Cheers,
                      Bob
