Questions on BLUsbUirt
  • Questions on BLUsbUirt
    First is it possible to send Ir commands in an event with out using scripts.
    Second is it possible to run this as a remote plugin. It would be really nice if it could be run on multiple client PC's with a USBUIRT on them.
    Cheers Ken
    HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
    The answer to both is no.
    I have only had time to get it up and running as it was in HS2. I believe that is what I said I would do. I had to rewrite about 75% of the plugin do to HS3 not dealing with the IR plugins. Had to rewrite the adding of devices and IR codes. It is possible I could add it later but it might be a bit before I have that much time to do it.
    Cheers,
    Bob
      See build 2.0.2 for event actions to send IR codes
      Cheers,
      Bob
        Any thoughts on making this run as a remote plugin so USBUIRTS could be run on other computers
        Cheers Ken
          It is not high on my list. Getting it converted is what I said I would do
          Cheers,
          Bob
            See HERE
            Cheers,
            Bob
              Thanks blade
              I will get it setup soon. I really appreciate it.
              Cheers Ken
              Sent from my EVO using Tapatalk
