IR output zone assignments?
  • IR output zone assignments?
    Thank you for getting this plugin ready for HS3!
    Are there plans to add the zone assignment feature to this plugin? The HS2 version could assign 1-4 for particular devices. I use this feature because I have two matrix switchers and if I assign the same output it changes both matrices instead of only the one I want. I have an IR eye over one of the matrices assigned to output 3 so it doesn't change the other one.
    I do see the check box to have the IR sent to all the zones but that wouldn't help either for the above reasons.
    Thanks again.
    Can you show me how you did it in HS2?
    Screenshots will help and explain exactly how it works. I am sure it is not difficult to add
    Right now I believe it sends it to all 4 of them.
    When you do the learning I believe you can override the repeat value there.
    Show me what you mean
    Cheers,
    Bob
      See if this helps. Switch1 is the one on a different zone to keep it by itself. The others use the built-in front IR blaster. The zones are drop down menus as show below as well.
        OK leave it with me.
        Cheers,
        Bob
          Try 2.0.4 in the HS3 updater and let me know if it is what you are looking for.
          You can now add zones and assign them to the IR commands
          Let me know
          Cheers,
          Bob
            Yes, this fixes the issue with the zones. I appreciate it!
              I figured 2.0.4 would fix it but I think you will still have issues.
              It looks like your IR codes are learned a little different than on mine.
              I am going to have to make a change to the plugin that will force everyone to re-add all devices and IR codes. Sorry about this
              I will post the new build shortly
              Cheers,
              Bob
                No problem. Since you put in your personal time to make this plugin ready for HS3 and kept it free, I have no problems putting in some extra time on my end to re-learn the codes.
