Not that I know of.
They really need to add support for vb.net single line script calls in the event actions and from the control panel page.
Nothing I can do about it. It has to be added in HS3
SendIR command?
Was this ever resolved? I have a ton of IR commands I'd like to use with HSTouch.
Apparently not:
May-16 9:37:49 AM Error Running script(2) &hs.PluginFunction("BLUSBUIRT", "", "SendIR", New Object(){"cable box","power"}), init error: Expected end of statement
I meant to log it on Bugzilla as a bug because Rich needs to fix this.
I cannot fix this one
Do not think it is fixed.
I have not logged a bug for it yet.
Can someone please log a bug for this and paste the bug report number here
Was this ever fixed? I need to send IR commands from HSTouch and am getting the error, "Running script, init error: Expected end of statement". Just like the original post.
Thanks.
Ok, in the mean time I created Manually triggered events to send IR commands and seems to be working.
Yea I cannot get scripting calls to work like that in the immediate script command window. I think that is an issue with HS3 because the same call works in a .vb script
i am trying this in the immediate scripting command of HS3 and it is not working:
&hs.PluginFunction("BLUSBUIRT", "", "SendIR", New Object(){"WD TV Play 1","enter"})
I am getting this error:
12/28/2013 9:06:40 PM ~!~Error~!~Running script, init error: Expected end of statement
Do you know what I am missing?
SendIR does exist in my plugin but it is not getting to the plugin for some reason.
I do not use HSTouch so I cannot test this.
I did run the command from a script and it works.
not sure if it helps, but this thread might be of use about the SendIR command and HS3.
http://board.homeseer.com/showthread.php?t=163992
The problem is that SendIR is not getting called in the plugin
It is never making it to the plugin.
doesn't appear to be getting any errors. I did the debugging twice. One from the HSTouch interface and one from the "control panel" of HS3.
edit: Could the addition of the "zones" change the way the Script should be formatted?Attached Files
Are you getting any errors?
Can you turn on debug logging in the plugin and then run the script call. Then turn off debug logging and attach the BLUSBUIRT-Detailed.log file and I will have a look
