IR Receive?
  • IR Receive?
    Blade
    Any chance of your Plugin being enhanced to also to IR receives?
    BTW The IR send function is working great. Thanks again for all your great work and contributions.
    I am sure it can be added.
    What would you want the plugin to do for IR receives?
    Cheers,
    Bob
      I haven't looked at the UIRT plug-in yet but in HS2 i use IR matching to trigger events such as turning lights down while the A/V equipment is starting up.
      Marty
      XPpro SP3 /w HS Standard 2.5.0.80, HSTouch Server - 1.0.0.70, HSTouch Client 1.0.0.73 HSTouch Android - 1.0.0.2, HSTouch iPhone - 1.0.0.2
      Playing with HS3 a bit but it's just play at this point.
        It looks like if the USB-UIRT receives an IR signal it sends it out.
        I had added this to the latest build.
        I do not have any triggers as I don't think there were any in the HS2 version.
        Cheers,
        Bob
          Exactly Nightwalker!
          Trigger event on a receipt if IR.
          One example that comes to mind is
          If I hit On via my man cave Receiver remote is would turn on the cable box and projector via IR sends from USBUIRT.
          Basically a very smart One remote where all the logic resides on HS.
          Didn't HS 2 handle IR receives within the HS logic. I think that is why the HS2 USBUIRT did not need them. Where as HS3 has left IR receive behind.
            In HS2 there is one trigger for IR Match and one Action to send IR command. To be honest I don't know if they were plug-in generated or with-in the scope of HS2 itself.
            Marty
              I have added the IR Match trigger to 2.0.6 in the HS3 updater
              Cheers,
              Bob
                Nice, as soon as I have something to try it with i'll give it a shot.
                Marty
                  Thanks Blade
                  I will give this a try later today after work.
                    IR Matching as a trigger to an event worked flawlessly.
                    Thanks Blade!
