IR Receive?
  • rwiese1
    IR Matching as a trigger to an event worked flawlessly.
    Thanks Blade!
  • rwiese1
    Thanks Blade
    I will give this a try later today after work.
  • nightwalker
    Nice, as soon as I have something to try it with i'll give it a shot.
  • Blade
    I have added the IR Match trigger to 2.0.6 in the HS3 updater
  • nightwalker
    In HS2 there is one trigger for IR Match and one Action to send IR command. To be honest I don't know if they were plug-in generated or with-in the scope of HS2 itself.
  • rwiese1
    Exactly Nightwalker!
    Trigger event on a receipt if IR.
    One example that comes to mind is
    If I hit On via my man cave Receiver remote is would turn on the cable box and projector via IR sends from USBUIRT.
    Basically a very smart One remote where all the logic resides on HS.
    Didn't HS 2 handle IR receives within the HS logic. I think that is why the HS2 USBUIRT did not need them. Where as HS3 has left IR receive behind.
  • Blade
    It looks like if the USB-UIRT receives an IR signal it sends it out.
    I had added this to the latest build.
    I do not have any triggers as I don't think there were any in the HS2 version.
  • nightwalker
    Originally posted by Blade View Post
    I am sure it can be added.
    What would you want the plugin to do for IR receives?
    I haven't looked at the UIRT plug-in yet but in HS2 i use IR matching to trigger events such as turning lights down while the A/V equipment is starting up.
  • Blade
  • rwiese1
    started a topic IR Receive?
    IR Receive?
    Blade
    Any chance of your Plugin being enhanced to also to IR receives?
    BTW The IR send function is working great. Thanks again for all your great work and contributions.
