Panasonic Codes
  • bmora
    Starting to think it may be a plugin issue. I used the Learn Helper Utility and that works fine with no issues. When I try to use that program to inject the code the plugin crashes as stated in another thread.
    http://board.homeseer.com/showthread.php?t=166160
  • bmora
    started a topic Panasonic Codes
    Panasonic Codes
    Not sure if it is a plug-in issue or what, but for some reason my TV is not responding to the transmitted IR code. I was able to learn the codes via the plug-in but the TV does not respond to the send codes. Had no issues with the HS2 plugin with the same TV. Is there a way to import the codes that are in the registry on my HS2 machine?
    I was able to learn my cable box codes no problems just for some reason the TV is not responding.
