Manually enter an IR code?
    Is there a way to manually enter an IR code?
    Samsung has 3 codes for power.
    Toggle on/off
    Discrete on
    Discrete off
    If I learn a command, it learns the toggle on/off.
    So if I create an event to turn the lights off, tv off, etc. It sends the toggle command which means if the tv is already off, it turns it on!
    I want to be able to send a discrete off command so if the tv is already off, it does nothing.
    Thanks!
    I am just now digging into IR on my new HS3 setup.
    I will also be looking to do this same thing. With HS2, I used some UIRT utility to paste in codes from remotecentral.com for discrete actions that can't be learned from the remote. Does this ability exist with UIRT for HS3?
    Thanks!
    HomeSeer 3, Insteon, Z-wave, USB-UIRT, Google Hub/Chromecasts/Smart Speakers, Foscam cameras, Amcrest camera, RCA HSDB2a doorbell
      I found the utility I used to inject those remotecentral.com ir codes. Can I post that here?
      http://www.remotecentral.com/cgi-bin/codes/
      That site has been very useful. Discrete IR control is very important in a home automation setup.
        I'll be damned, it worked! Well, this version worked. The later versions I had complained about some missing .dll file.
        For those looking for discreet codes:
        http://files.remotecentral.com/library/3-1/index.html
        1) Run the attached app
        2) Enable learning via the HS3 plugin
        3) This app will then display a new button w/ 'Inject' on it
        4) Press it
        5) Press 'No match' on the plugin learning window that is waiting for a second press
        Enjoy! I know I will, assuming no progress on the HS2 import script...
          Boy do I feel stupid. I should really read and try more things before I post:
          http://forums.homeseer.com/showthread.php?t=166231
