Ancient IR Codes
  • Ancient IR Codes
    Hi guys,
    I have some old IR codes I'd like to use. We're talking about codes from just after the Ancient Egyptians discovered Infra Red and used it in pyramid design.
    Okay, maybe not true but they are old, from way back when on Homevision that I've used for more than a decade to make stuff happen. A Pronto or three have these codes and all I need to do is make HS recognise them so I can fire off a macro when it "sees" them.
    For Blade, dude, thank you for this plugin as even if I can't get this to work somehow it is cool.
    What I have is the likes of the following IR code string from HV that I want to get HS to recognise...
    0000 006c 0022 0002 0160 00b0 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0462 0160 0058 0016 0cfa
    What that does is tell HV to shut the house down and go into a sort of sleep mode, stuff works different at night.
    The question is, is there an easy way for me to just lift these codes from the old HV and get them into the UIRT plugin?
    I tried the learning thing briefly but I didn't get it to work. I will freely admit, I didn't exactly put a whole heap of effort into it as if I can past in these codes I'm golden.
    Thanks for any help.
    K.
