Remote, and Multiple instance clarification
    Shoot, I don't know what happened. I can't seem to delete these duplicate posts.
    HomeSeer 3, Insteon, Z-wave, USB-UIRT, Google Hub/Chromecasts/Smart Speakers, Foscam cameras, Amcrest camera, RCA HSDB2a doorbell
    Figures...the admin deletes the real post and leaves the one apologizing for the duplicate posts. No comment on the admin...just my luck.
    Anyway, from the other post about remote instances, it seems clear that two remote instances running at the same time is not possible with the current state of the plugin.
    My question is, can I run a local instance AND a remote instance at the same time? Or can I only run one UIRT, no matter where it is.
      That is correct - only one instance and no remote
      I only converted the old USBUIRT plugin from HS2 to HS3. I did not add anything else to it
      Cheers,
      Bob
        Oh, wait...I'm confused. I never said "no" remote. Did you mean "one remote"? I assume remote works because of that one "Sticky" in this sub forum.
        BTW, thanks a ton for converting this plugin, and doing it for free. I know Jon Reese required it be kept free.
        Assuming you meant "one remote" and the remote feature works, I would definitely pay for the multiple instance feature. I know you said it would require a bit of work. I bet Jon would let you charge for an improved version of the plugin or a wrapper that allows for multiple instances of the free plugin.
        A few UIRTs are a LOT cheaper than the Global Cache options out there...as far as I can tell. This could be huge! What do you think? What would make it worth your time?
          Yes you can run it remotely - just multiple instances not supported right now
          Cheers,
          Bob
            Thank you for the confirmation.
            FYI, I don't even require discrete zones. I don't have any identical equipment that I need to send IR to separately. I'd be happy if HS just sent to all, and received from all UIRTs simultaneously. I think of this scenario as an extension of a single instance, but I'm not really sure what an instance is.
            Have a great day!
