Warning message in log files
  • Warning message in log files
    Hi,
    I've noticed that I get the following warning message in my HS3 log file repeating:
    BOSESoundTouch Warning Error: The request timed out
    I notice it happens when HS3 is rebooted. I have to disable the plug-in and enable it. This stops the warning. the warning is logging on every scan of the processor filling up my log files with the same message.
    I have not been able to reproduce the error. I'm still looking into it. Are you running on Windows or Linux/Raspberry Pi HS3?
    thanks,
      Linux
        I'm using a Hometroller SEL. I find if you just unplug the controller then plug it back in the warning starts to log
          Any feedback on this?
            Jan-02 7:18:10 AM BOSESoundTouch Warning Error: The operation has timed out
            Jan-02 7:18:09 AM BOSESoundTouch Warning Error: The operation has timed out
            Jan-02 7:18:09 AM BOSESoundTouch Warning Error: Unable to connect to the remote server
            Jan-02 7:18:08 AM BOSESoundTouch Warning Error: The operation has timed out
            Jan-02 7:18:07 AM BOSESoundTouch Warning Error: Unable to connect to the remote server
            These logs are filling up my log entries files every two seconds. What does this mean? It's happening on a HomeTroller SEL and S6
            Current Date/Time: 1/2/2018 9:55:54 AM
            HomeSeer Version: HS3 Standard Edition 3.0.0.368
            Operating System: Microsoft Windows 10 Home - Work Station
            System Uptime: 2 Days 16 Hours 40 Minutes 27 Seconds
            IP Address: 192.168.1.64
            Number of Devices: 185
            Number of Events: 47
            Available Threads: 199
            Enabled Plug-Ins
            3.9.8.1: BOSESoundTouch
            0.0.0.19: DoorBird
            3.0.0.56: DSC Security
            3.0.0.40: EasyTrigger
            3.6.5.0: Harmony Hub
            1.1.17344.311: MyQ
            1.0.2.0: MyS0mfy
            3.0.0.28: Nest
            3.0.0.76: weatherXML
            3.0.1.130: Z-Wave
              I am seeing the same thing. I am also on SEL
